2003 Durango Window Regulator Help
Old May 11, 2009 | 11:37 AM
Katt79's Avatar
Katt79
Default 2003 Durango Window Regulator Help
I have replaced the Driver front window regulator twice in the last year and now it needs replaced again. I know there are issues with the windows on Dodge’s but my question is should I be replacing it that often? Is there something else I should be doing beside buying the new window regulator and replacing it?
Old May 11, 2009 | 12:07 PM
Neo1130's Avatar
Neo1130
Lube the window tracks... Especially where the window and weather strip meet... There is a special lube that you can get for the windows....
Old May 11, 2009 | 09:04 PM
schusterjo's Avatar
schusterjo
We would spray lithium grease in the entire rail back when i did auto glass.
Old May 12, 2009 | 12:46 PM
Kensai's Avatar
Kensai
Also, are these replacements the same replacements from the manufacturer or did you try different manufacturers?
