code errors keep coming up
Old May 15, 2009 | 08:25 PM
famemob702's Avatar
famemob702
Default code errors keep coming up
hello just wanted to know if anyone knows what i need to get rid these lights. i have a check light, abs and brake lights on. now i had changed out the speed sensors and output sensor frot and rear. now after changing out both of them. it is still reading the output sensor. someone help me dont know what to do now......
Old May 15, 2009 | 08:50 PM
schusterjo's Avatar
schusterjo
Have you changed the sensor on the rear axle? it sits on top of the rear axle....... if not then thats usually the ABS light issue.
Old May 15, 2009 | 10:23 PM
famemob702's Avatar
famemob702
yes i did replace it on both sensors. rear abs sensor and the speed sensor on the trany. and the check light, abs and brake light is still on.
Old May 16, 2009 | 01:56 PM
hydrashocker's Avatar
hydrashocker
So you changed out the input and output transmission sensors. And also you changed out the Rear axle speed sensor.
If you have done this check the fluid level. Other than that I would recommend you take it to the stealership. They are the only ones with the ABS reader. But I could suggest the ABS Module. Seen them rebuilt on ebay.
