2000 Durango replace power steering
Old May 28, 2009 | 04:22 PM
mj8's Avatar
mj8
Default 2000 Durango replace power steering
I've never done this before but I'm fairly competent or I wouldn't' even be attempting it ok now to my question.
I know the pressurize line that goes from the pump to the steering rack is leaking and I will replace that. While I'm in there I should replace the return line and even the pjmp. Is there anything else that I am missing that may need to be replaced? How difficult is it to get the pump out? Are there any how to's to walk me through this process. Also do I use the clear power steering fluid or ATF-4?
2000 Durango with 5.2L
Old May 28, 2009 | 09:35 PM
IndyDurango's Avatar
IndyDurango
If your replacing everything, switch to ATF+4.
If you keep any of the old parts, stay with what you have in there.
IndyD
Old May 28, 2009 | 11:14 PM
hydrashocker's Avatar
hydrashocker
Use ATF+4
