Engine Code P033/P035
Old Jun 1, 2009 | 09:56 PM
tonylot's Avatar
tonylot
Default Engine Code P033/P035
Has anyone ever had the above codes when performing the diagnostic test? My 03 Durango will not start and those are the codes that are being displayed. I replaced the fuel pump in September and gave it a tune up. It has been running fine since then until now. Help!!!!!
Old Jun 1, 2009 | 11:33 PM
IndyDurango's Avatar
IndyDurango
It's a 4.7 right? You may be missing a digit. Like P033X and P035X. Cam position sensor and ignition coil pack. Probably the prior causing the later. Fix the first and check again.
IndyDurango
Old Jun 2, 2009 | 05:53 PM
hydrashocker's Avatar
hydrashocker
Coil.........?
You need to have those code re-read.
