Strange clank noise
Old Jun 25, 2009 | 09:43 PM
NAR7KX's Avatar
NAR7KX
Default Strange clank noise
Whenever I'm driving slow (5mph-10mph) in a parking lot or whatever, and i let off the accelerator there is a load clank sound coming from underneath the vehicle and it jolts a little into gear. What could be the cause of this?
By the way I've got 175,000 miles on my girl.
Old Jun 25, 2009 | 10:00 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
ok well we need a little more info, year, engine, drivetrain (4x4, or 4x2) trans (if you know it) t-case (if you know it) which rear end, and is it limited slip or posi, all of these things could be related to the issue, and the more info we have to work with the more likely we will be able to give you an accurate answer, and we are likely to ask for mor infor, it is nothing personal, just trying to help
Old Jun 26, 2009 | 02:56 PM
hydrashocker's Avatar
hydrashocker
Info please?
Old Jun 26, 2009 | 05:29 PM
NAR7KX's Avatar
NAR7KX
Its a 1999 5.2L V8 Magnum 4x2... That's all
Old Jun 27, 2009 | 12:56 AM
IndyDurango's Avatar
IndyDurango
Universal Joint
Old Jun 28, 2009 | 01:03 AM
hydrashocker
Make sure your fully out of 4X4 by backing up turning the wheels all the way right back 5 ft - back strait 5 ft - turn the wheel to the left fully and back 5 ft - back 100 ft strait.
Could be a ball joint as well.
Old Jul 2, 2009 | 03:40 PM
datacop's Avatar
datacop
Originally Posted by IndyDurango
Universal Joint
Second!!!
More than likely the rear one... Fix it asap before it fails and you end up having to replace the drive shaft cause it bounced on the road and broke the joint cups (no.. no experience with that at all.. nope..)
