want to bypass 2001 infinity amp.
Old Jul 14, 2009 | 05:38 PM
shadbehnke's Avatar
shadbehnke
Default want to bypass 2001 infinity amp.
putting in new speakers, and want to bypass or w/e i have to do to make my aftermarket speakers sound like they should! what do i do? thanks
Old Jul 14, 2009 | 08:08 PM
hydrashocker's Avatar
hydrashocker
The factory speakers are 2ohm not 4ohm. If you want to use the OEM amplifier then buy 2ohm speakers. www.crutchfield.com
If you want to take it completely out then it is located in the passenger side kick panel and then re-wire the whole truck and save the amplifier if it's good.
Old Jul 14, 2009 | 08:22 PM
shadbehnke's Avatar
shadbehnke
re wire the whole truck? wouldn't that be hard? i heard somewhere that you can just bypass the amp without running all new wire is there an easier way?
Old Jul 14, 2009 | 08:27 PM
shadbehnke's Avatar
shadbehnke
so if i get some 2 ohm they'll sound like the stock? here are what im interested in, will they fit and sound right if i use the stock plastics moiunts?
http://cgi.ebay.com/2-KICKER-08CVT65...3%3A1|294%3A50
Old Jul 15, 2009 | 12:43 AM
IndyDurango's Avatar
IndyDurango
Nope. Not unless you want to put sub woofers in your doors and have no sound at all. Name:  icon_confused.gif
Go to the Infinity's and look for that same size in 2ohm. The correct Kappas will work with both the stocker amp and a new one if you decide to get something better down the road. No need to swap speakers twice.
HTH,
IndyDurango
