power window problem
Old Jul 21, 2009 | 09:30 PM
tj_jokestar's Avatar
tj_jokestar
Default power window problem
I have a 2001 durango and the passenger window wont roll up or down with the passenger door switch but it will work from the driver side panel, its not the safety button because the rear window switch works and i've replaced the passenger door switch. I'm thinking that maybe a fuse? but i dont think there is a dedicated fuse for it. I'm just lost.
Old Jul 21, 2009 | 10:32 PM
hydrashocker's Avatar
hydrashocker
Most likley the drivers side master door swich needs replaced. There are diodes that go out in them causing these issues. To ensure this, test for power going to the pass switch and check connections first.
Old Jul 23, 2009 | 11:29 AM
tj_jokestar
yeah that was it the driver side wires were pinched or something because i pulled off the panel an it started working thanks
Old Jul 24, 2009 | 12:42 AM
hydrashocker
Thanks for the update and glad to see your moving without cash out of your pocket!
