1999 Durango Right side door?
Old Jul 25, 2009 | 09:12 PM
1999_Durango_SLT's Avatar
1999_Durango_SLT
Default 1999 Durango Right side door?
How hard is it to replace the drivers side door? Mine is badly damaged and I can get another door and it looks like 2 bolts hold it on besides the speaker wires and mirror as that is electronic too. Is there really much to it than what I explained? Oops sorry for saying right I meant left Front.
Old Jul 25, 2009 | 10:30 PM
schusterjo's Avatar
schusterjo
It not that hard to change it.. Its actually 4 bolts that hold the door hinges. I have done this and the biggest issue if doing it yourself is the dang door is pretty heavy. takes a few tries to get it aligned in there perfect. Best to have a friend help ya so you can hold the door while they loosen and tighten the bolts for adjustment. basically what ya do is close the door and look at it, see where you need to move in order to make it aligned, open the door hold it and have a friend loosen the bolts just enough to where you can move the door by having to push on it pretty hard, this way it does not move a lot if you know what i mean. thats pretty much it. I had the fender off at the time so that made it alot easier for me to get to the hinge bolts.
Old Jul 25, 2009 | 10:49 PM
1999_Durango_SLT
Thanks will be getting the door if I can tomorrow.
Old Jul 26, 2009 | 06:51 PM
schusterjo's Avatar
schusterjo
you know i said 4 bolts and that is wrong, it is 6 bolts 3 per door hinge. the one in the upper/back kinda is a pain to get to. Let us know how it goes for ya..
