horn help
I got a set of these: http://www.jcwhitney.com/autoparts/S...&zmap=ZX128359
and I think that theyre supposted to go where the stock ones went. but is there a way how I can just splice the wires that go to the horn and add these in so when I "honk" both the stocks and these blow at the same time?
and I cant tell in the instructions but these just replace the stock wiring correct? the instructions are as good as a polock. no ofense to anyone that is
Well it looks like you may just need to use the old wiring but have noway in telling without seeing the instruction that come along with it.
Should work though.
Should work though.
Well black is almost always ground, the other should be positive..
