Still have code p0733
Old Sep 5, 2009 | 10:18 AM
tetanusshot's Avatar
tetanusshot
Default Still have code p0733
Ok, after a new cranshaft pos sensor and speed sensor on the trans, i still have the same damn code. In D, when you take off, it shifts into 2nd, then when it's supposed to go into 3rd, it shakes a lil bit then downshifts into 1st and CEL comes on. If you take off in 2, it works fine. What gives?
From what I have been reading on the web, it sounds like the accumulator plate is shot and there happens to be a repair kit for it. Anyone have an idea where I can get this repair kit at?
Old Sep 5, 2009 | 09:42 PM
tetanusshot
umm, anyone?
Old Sep 6, 2009 | 03:49 AM
hydrashocker's Avatar
hydrashocker
First off year and motor?
Sounds like the CEL needs to be read........Sounds like a 3-4 shift solenoid though.
Old Sep 6, 2009 | 09:37 AM
tetanusshot
its a 02 4.7L 2wd
Old Sep 6, 2009 | 09:46 AM
schusterjo's Avatar
schusterjo
Yup year engine size?
When is the last time you changed the fluid and adjusted the bands?
Old Sep 6, 2009 | 10:35 AM
tetanusshot
with 80000 miles, i doubt the fluid has been changed and iirc, the bands aren't adjustable.
Old Sep 6, 2009 | 10:36 AM
tetanusshot
p0733 and p0734
Old Sep 7, 2009 | 12:03 PM
tetanusshot
Anyone?
Old Sep 7, 2009 | 04:45 PM
hydrashocker
P0733 Gear 3 Incorrect Ratio
P0734 Gear 4 Incorrect Ratio
Sounds like the 3-4 shift solenoid.
There are no bands in that trans so drop the pan replace the solenoid and filter and replace and fill.
Old Sep 7, 2009 | 11:55 PM
IndyDurango's Avatar
IndyDurango
+1. No bands there.
IndyD
