Transmission Troubles
I have an 01 Durango
that recently lost all forward and reverse gears. There was no warning and no noise or slippage, just gone at once. I have removed the transmission, transfer, and torque converter and noticed that there is a gear in the throat of the torque that seems to flop around when the converter is tilted from side to side. I was thinking along the lines of a torque converter or pump problem as all gears were gone at once, and after seeing this inside the converter I was wondering is this is where my problem lies.
I appreciate any and all help on this matter as I am not a mechanic, and I do not wish to change the trans if the converter is my problem. Thanks in advance.
Rich
that recently lost all forward and reverse gears. There was no warning and no noise or slippage, just gone at once. I have removed the transmission, transfer, and torque converter and noticed that there is a gear in the throat of the torque that seems to flop around when the converter is tilted from side to side. I was thinking along the lines of a torque converter or pump problem as all gears were gone at once, and after seeing this inside the converter I was wondering is this is where my problem lies.I appreciate any and all help on this matter as I am not a mechanic, and I do not wish to change the trans if the converter is my problem. Thanks in advance.
Rich
