RPM's spiking
Old Nov 17, 2009 | 05:30 PM
hawkeye4jw's Avatar
hawkeye4jw
If there were no codes when we put it on a scanner, do I still need to reset the PCM?
People on allot of these forums know more then most mechanics about our vehicles.
Thanks Jack
Old Nov 18, 2009 | 12:11 AM
hydrashocker's Avatar
hydrashocker
Yes.
It doesn't matter if you through a CEL or not, if you change the flow design (in any way!) then a reset for the truck to re-learn the system that way it does what it's designed to do.
Do you have to? NO
But should you? Yes
The other thing you can do is set the TPS so that you have better responce and power. You should clean the TB and do this free modification:
Throttle Position Sensor Modification for increased Performance. Scroll to TPS Modification:
http://bionicdodge.com/Download/Spee...d%20Tricks.pdf
Old Nov 18, 2009 | 06:08 PM
hawkeye4jw's Avatar
hawkeye4jw
Thanks. I will try to reset it this weekend. I want to clean the TB and do the TPS mod but may not be able to get to it until spring. Thanks for all the help and tips.
Jack
