Pcv
Old Oct 29, 2009 | 03:45 PM
Zazoos's Avatar
Zazoos
Default Pcv
2002 Durango 4.7
Is this the PCV valve?
Thanks
Trent
Old Oct 29, 2009 | 10:40 PM
IndyDurango's Avatar
IndyDurango
No. That is a one way vacuum valve I believe.
With that said, I am not a 4.7 guy so I could be wrong. PCVs are usually IN the valve cover.
IndyD
Old Oct 30, 2009 | 01:08 AM
hydrashocker's Avatar
hydrashocker
Thats a vacuum check valve.
I think it is directly in front under the Throttle Body and has a black tube going to it. It goes strait up under the Throttle Body. You can see it from the outside.
