I'm thinking of switching to Duralast products, for the convenience and ease of warranty returns. I replaced my entire front end with Moog parts in May of 07. Since then I replace both lower ball joint (torn boots), left inner tie rod and the right outer tie rod. Today I did my pre-winter inspection, which showed I need to replace the idler arm and the right inner tie rod. All of the parts are Moog, is their quality going down? I don't go offroading, although some consider driving through NY potholes is like going offroading. The Moog parts were ordered through Rockauto and come with a lifetime warranty. All parts have or will be replaced. Which means the truck would down until the parts arrive and are installed. I have some spare parts which will keep me on the road, but 2yrs on Moog parts I might as well use Duralast. I can change them every 2yrs if need be and if they last longer it would be a plus. I do my own work, so labor charges don't apply. If you were me, what would you do?
Well somehow 1 upper got away from me as the drivers side upper is out again after 2 years. It was a Duralast but I'm going to replace them both in a week or so.
