Rear Axel Speed Sensor / Rear ABS Sensor DIY
Old Aug 26, 2012 | 12:33 PM
  #21
birchy's Avatar
birchy
Have any of you had the sensor break off on you while trying to remove it? I was trying to do this on a friends Durango yesterday and the damn thing broke flush with the differential! I managed to get the inside "magnet" piece out, but the plastic sheath is still stuck in the hole and I plan on having another go at it this morning...
Any tips or suggestions? Does anyone know of some sort of tool that is like a small screwdriver, but with a metal "L" hook at the end? I'm sure i've seen something like that before somewhere.. but I can't remember where. That might work.
Old Aug 26, 2012 | 03:09 PM
  #22
birchy's Avatar
birchy
Alright.. so I found a set of "picks" in Walmart today that had the L hook I was looking for. Worked like a charm! Amazing how much easier things are when you have the right tools! I was fighting with it for an hour yesterday and it took me 30 seconds this morning..
Unfortunately.. the ABS and Brake lights are still on after taking a ~15 minute drive around the neighbourhood. Disappointed.. I was really hoping that would fix it.
Old Aug 26, 2012 | 03:54 PM
  #23
srch4me's Avatar
srch4me
Did you reset the computer?
Posted from Dodgeforum.com App for Android
Old Aug 26, 2012 | 03:57 PM
  #24
birchy's Avatar
birchy
I don't have a way too unfortunately.. after reading through the threads I was under the impression the lights would go off as soon as I started driving pretty much. Is that not the case?
Old Aug 26, 2012 | 05:38 PM
  #25
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
sometimes it is not the case,
if you are capable of replacing your battery you are capable of resetting the PCM, just disconnect the battery and hold the key to start for 30 seconds (while the battery negative post is removed) then put the neg terminal back on.
Old Aug 27, 2012 | 12:20 AM
  #26
birchy's Avatar
birchy
Cool, thanks.
"Start" as in.. turning the engine over? Or just the "ON" position?
Old Aug 27, 2012 | 10:59 AM
  #27
DaveKDEN's Avatar
DaveKDEN
Default ABS/park brake lights came back
Well, started having issues with the ABS and park brake lights coming on intermittently again (not too long after returning from my trip mentioned in my earlier post). Heard about a place that "re-builds" ABS modules (and other types as well). Modules masters in Moscow, ID:
http://modulemaster.com/en/index.php
Sent my ABS module to them about a month ago. Took a total of 1 week including shipping to get it back. Works like new now. Wish I would have known about them before. Would have saved me much angst. If you've tried everything else (and I would say try the rear speed sensor first) - give module masters a shot.
Old Aug 27, 2012 | 07:28 PM
  #28
shrpshtr325
THE ULTI-MOD
Cool, thanks.
start as in all the way to turn the engine over, it obviously wont turn over but the idea is to provide a closed circuit to the starter motor to pull and residual energy out of the capacitors, completely denergizing the system as such resets the volatile memory where the codes are stored, Keep in mind the truck may run differently for a little bit after following this procedure since all the 'learned' data is also erased.
Old Aug 29, 2012 | 09:04 PM
  #29
birchy's Avatar
birchy
That didn't work either, unfortunately. The lights come back on right away the next time I start it up, and stay on. I'm thinking maybe it's the other sensor on the transmission, but I really don't want to spend too much more time and effort on this thing.
Old Aug 30, 2012 | 04:38 PM
  #30
shrpshtr325
THE ULTI-MOD
the output sensor on the transmission is cheap and easy to change, costs around $20 and if you are even a little bit capable of turning a wrench will take you longer to walk into the store and pay for it than to install it.
