Brake Controler
Old Nov 22, 2009 | 02:07 PM
cabmkr's Avatar
cabmkr
Default Brake Controler
Where is the brake controler hookup located on a 2000 durango slt 4x4, with a 4.7. On my 2006 2500 it was on the left near the bottom of the firewall but dosent appear to be in the sam place on the Durango
Thanks Chris
Old Nov 23, 2009 | 12:19 AM
hydrashocker's Avatar
hydrashocker
It is light blue in color and on the drivers side above the wiring harness in the corner (far drives side) kinda above where the old dimmer switches used to be on older trucks.
If you didn't have a factory tow package then it might not have been installed.
Old Nov 23, 2009 | 11:22 PM
gr8scott72's Avatar
gr8scott72
Yup, gotta have the factory tow pack. If you don't, it's not really that hard to wire it up yourself. Power, ground, and brake signal (from the brake pedal switch) to the controller and output line from controller to rear tow wire plug.
Old Nov 25, 2009 | 06:51 PM
cabmkr's Avatar
cabmkr
Thanks guys, after a good look found the plug behind the wiring harness, my 06 cummins was much easyer to access
Cheers
