Fuse D ????
Old Jan 23, 2010 | 10:57 PM
hydrashocker's Avatar
hydrashocker
It is in the fuse box in the dash above the E-brake. In the 1998-1999 it's on the bottom left side little relay box. In the newer models it is behind the fuse box in a secondary fuse panel. They are like $10 bucks so get one and look at it. They look like a relay and they simply plug in.
Old Jan 24, 2010 | 12:31 PM
ronisi's Avatar
ronisi
i'll check it out.so when ask for it what is actually called
Old Jan 24, 2010 | 06:53 PM
hydrashocker
combination flasher
Old Jan 25, 2010 | 12:15 AM
Dans01Durango's Avatar
Dans01Durango
What's it called again?...
Old Jan 25, 2010 | 11:51 PM
hydrashocker
Blinker fluid!.....
Old Jan 26, 2010 | 12:37 AM
Dans01Durango
That's it! Thanks!
Old Jan 26, 2010 | 03:54 PM
ronisi's Avatar
ronisi
I went to dealership and asked for a combination flasher and even told them FL27 should be printed on it and it didn't come up on there computer.There was 1 flasher that showed up but didn't have a picture.Anyways they told 3-5 business days and 100 dollars. That can't be the same one as on A/Z website for 15.99.I just noticed when pumping brakes I hear a clicking sound too. New brake light switch and still the 3rd light works the turn signals work to.
Old Jan 26, 2010 | 11:05 PM
hydrashocker
Go to AZ dude.
Old Apr 17, 2010 | 11:42 AM
goldstamping's Avatar
goldstamping
Default Location of Combination Flasher
Hi, I have the exact same problem as this poster and have verified all fuses are ok, and I have replaced the Brake Switch...so I am thinking the combination flasher must be the issue here also. Now, my problem is this, where is the silly thing. I have read all the threads here and for the life of me I can not see how to access a secondary fuse panel behind the main one. Could you post a pic, or some quick step by step instructions for it. Thank you.
