Can condensation in fog light blow bulbs?
Old Feb 11, 2010 | 10:01 AM
Kidd_Funkadelic's Avatar
Kidd_Funkadelic
Default Can condensation in fog light blow bulbs?
I have a question- If a fog light has a bad seal and continually gets condensation in it, and I blow bulbs several times a year, would the condensation be to blame?
This has been going on for some time. The main reason I wonder is that when the bulb dies, it tends to look just fine with the exception of the filiment connection no longer being there. There's no bulb damage (like the blackness you see on a blown fuse, etc). In other words you'd have to really look up close at the bulb to see if it was any good or not. Or would this suggest another problem and the moisture in the fog housing is unrelated? Note the other side has never blown a bulb (and has no moisture).
Thanks for any insight! I'm sick of buying a new bulb every 4 months. But on the other hand I don't want to spend 40 bucks for a used fog light housing if that's not going to help me either...
KF
Old Feb 11, 2010 | 01:26 PM
Dans01Durango's Avatar
Dans01Durango
Condensation will crack a hot bulb sometimes resulting in failure. You can seal up the crack with silicone and see if the housing is solidly attached to the frame. Vibrations can affect bulb life. OR... you can spend $40 and go to AZ and get a pair of replacment fog/driving lights. I think the dia. of the stock fog housing is 4 in. If you use the fogs this much. I'd look into aftermarket lights. JMHO.
Old Feb 11, 2010 | 11:27 PM
hydrashocker's Avatar
hydrashocker
Yes!
Clean out the condensation and check the O-ring or gasket on the plug to light seal point.
Old Feb 12, 2010 | 07:41 AM
Duranged408's Avatar
Duranged408
What bulb brand do you use? By you mentioning just coil degrading could just be a crappy type of bulb, try using a basic sylv halogen next time and make sure the connections are good and dont touch the bulb
