transmission issue.
Old Feb 12, 2010 | 04:28 PM
mb98d's Avatar
mb98d
Default transmission issue.
my 98 5.2 4x4 shifts into second then straigt into third gear then it jumps back and forth between the two when i accellerate normally. i have noticed that it only happens at certain places in the throttle. if i push it softer it doesn't do it and if i push it harder it doesn't do it. it also will not shift out of first gear if i go wide open throttle. i just changed the fluid and filter at the begining of january. fluid level is correct. any help would be much appreciated.
Old Feb 12, 2010 | 07:42 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
did you adjust the bands? you will need to drop the tranny-pan in order to do this and also check to tv (kickdown) cable from the throttle body to the transmission
Old Feb 12, 2010 | 07:52 PM
Mastec's Avatar
Mastec
I had this issue last summer. The trans needed rebuilt when band adjustment didn't work. I was thankful mine was still under warranty.
Old Feb 12, 2010 | 08:19 PM
mb98d's Avatar
mb98d
no i didnt adjust the bands because i forgot my inch pound torque wrench at work. is there a thread about adjusting bands or the tv cable?
Old Feb 13, 2010 | 12:22 AM
shrpshtr325
THE ULTI-MOD
i know it came up not too long ago in a thread, but im not sure which one, if you do a search it should come up, but your best bet is a chilton or haynes manual the specs should be in one of those (or maybe someone on here can just post up the procedure for you w/ the specs)
Old Feb 13, 2010 | 11:56 AM
mb98d's Avatar
mb98d
ok thanks
