Gauge cluster says 'no bus'
Old Feb 26, 2010 | 11:23 PM
hydrashocker's Avatar
hydrashocker
+ 1 Sharps
There's a bad connection somewhere?????
Old Feb 27, 2010 | 01:56 AM
IndyDurango's Avatar
IndyDurango
-2 knuckleheads!
Do not take the needle off. No need. The needles will freely move if you have the whole cluster out... WHICH IS NOT NEEDED.
Run the needle calibration test and see if that pulls it back to where it should be.
IndyDurango
Old Feb 27, 2010 | 09:11 AM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
i was thinking just push it around till its on 0, do not take it off, but i would try indys test if it doesnt involve taking the dash apart again (tho i have never heard of that test so, indy post up the how to )
Old Feb 27, 2010 | 11:59 AM
bain64's Avatar
bain64
Ok I am back to square one, got the speedo fixed by holding down the trip button while turning the ignition to on, let it run the sequence then start the truck. The gauges go crazy for a minute and then everything went back to the way it was.
Now as to the original problem, i found the wire that you have to wiggle that makes the entire gauge cluster die and say no bus. I will go take some pictures of it now and hopefully you guys can tell me what the heck it is.
Old Feb 27, 2010 | 12:12 PM
bain64's Avatar
bain64
I know I double posted, but thought I would get more attention to the current problem rather than the speedo stuck issue that is now resolved.
The problem seems to be under the glove box.
If I wiggle the little green wire on the right I can make the gauge cluster, radio and interior lights die and turn back on. I can do the same with those wires on the left but it is much easier to do with the one on the right. What is that little canister the wire is connected to? Of course the bad connection seems to be at the far end of the wire, not the visible end.
Old Feb 27, 2010 | 02:04 PM
bain64's Avatar
bain64
triple post now, but i got it fixed. just under that kick panel there was a loose ground. Thanks for the replies guys!
Old Feb 27, 2010 | 03:35 PM
hydrashocker
Nice update!
Old Feb 27, 2010 | 05:26 PM
shrpshtr325
THE ULTI-MOD
good find man
Old Feb 27, 2010 | 11:25 PM
bain64's Avatar
bain64
I was happily surprised that it only took a few hours to find (not counting time spent on Google). I was expecting an all day project.
