Idle Surging
Old Mar 5, 2010 | 10:09 AM
bain64's Avatar
bain64
9 year old battery, wow! Congrats on that.
Old Mar 5, 2010 | 11:35 AM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
a weak battery will cause the computer to act up, might be responsible for the code (tho i have never seen it before) replace the battery and see if the code comes back
Old Mar 5, 2010 | 01:55 PM
hydrashocker's Avatar
hydrashocker
I like DuraLast batteries from Auto Zone with their 8 year warranties and and pricing! A 9 1/2 year old battery is well past expiration date!
Old Mar 5, 2010 | 02:17 PM
atvmax99's Avatar
atvmax99
Well I scored the Interstate battery, found an Interstate "Platinum" dealer in the area and he had 1 in stock, $121.10 with the sales tax. This thing looks like it belongs in a submarine, 47.4lbs! Didn't really take took much notice in the past just how big the Durango's battery was, anyway I'll get the brother-in-law over on the weekend to help me with it and I'll see what this does for it, especially since disconnecting the battery will clear out the codes again.
Old Mar 5, 2010 | 04:56 PM
scientist's Avatar
scientist
I had the same issue. Replaced IAC and TPS sensors and clean everything that was suggested. What "solved" the RPM fluctuation was making sure that the correct level of transfluid when the engine was warm and in neutral. Give it a try might solve your issue
Old Mar 5, 2010 | 05:47 PM
atvmax99's Avatar
atvmax99
Easy enough to check, that's a bizarre solution. How low was it on yours?
Old Mar 8, 2010 | 12:46 PM
scientist's Avatar
scientist
I was one quart short
Old Mar 8, 2010 | 03:23 PM
shrpshtr325
THE ULTI-MOD
yes low trans fluid - low fluid pressure and can do odd things to the torque converter (cause it to try and lock up in park, or not unlock going to a light) which puts xtra load on the engine causing rpms to go up
Old Mar 10, 2010 | 07:30 PM
atvmax99's Avatar
atvmax99
Trans fluid level was fine. Changed out the battery and P0601 came back, idle is steadier than before, wanders between 600 and 900 and then will setlle to a fixed 600 but so far it hasn't done that 2000 idle since the new battery. I'm fine with it this idle now and as far as P0601, screw it! It runs fine, I'm not fixing what isn't broke not to mention the serious $$ getting rid of this code.
Old Mar 11, 2010 | 10:18 PM
shrpshtr325
THE ULTI-MOD
i hope that you checked with the engine and trans warmed up in neutral and all that other good stuff
