Fender mounted signal lights
Old Mar 31, 2010 | 05:57 PM
hydrashocker's Avatar
hydrashocker
Originally Posted by avarvarigo
I guess I'll have to remove the headlight asm to get to the wiring? from a fast look, it seems as the wiring harness is not easily accessible otherwise...Am I correct?
TV
Are you taking about removing the head lights just for the wiring?
Old Mar 31, 2010 | 07:05 PM
avarvarigo's Avatar
avarvarigo
Hi again, Hydra. Yes. I was talking about removing the headlight asm or the marker/turn signal portion so I can tap off the wiring that goes to the front signals to run the new side repeaters, (as they call them). Or is there a better way?
TV
Old Mar 31, 2010 | 08:10 PM
avarvarigo's Avatar
avarvarigo
Hi, I believe this is for Indy with the Fast D from NJ. Where did you get those side blinkers from if you remember? I like them.
TV
Old Mar 31, 2010 | 08:16 PM
MAGIC84's Avatar
MAGIC84
A storm was coming and it was the end of the show late Sunday. Hell yea we stuck 'em in the tent.
Bonus points... identify the guy in the blue shirt looking at my Durango
I resemble that bonus point!!! Not sure who he is but must be a great guy, professional, caring, full of technical knowledge.
Old Mar 31, 2010 | 11:20 PM
Dans01Durango's Avatar
Dans01Durango
You don't have to remove the whole headlight asmb. Just the corner lights. Just make sure which wires you're gonna tap from cause we have a steady on and blinkers. Oh yeah, you can route the wiring across the inside of the fenders and zip tie them to the body. HTH.
Indy, can't say who the gentleman is in the blue shirt but I concur with magic's discription.
Old Apr 1, 2010 | 12:34 AM
IndyDurango's Avatar
IndyDurango
Originally Posted by Dans01Durango
And of course you two hot shots got the tent
I should have said, "It's good to be the King!"
Dan, that **IS** Magic. Not so sure his description is accurate, but the photo is.
IndyD
Old Apr 1, 2010 | 09:19 AM
Dans01Durango
IndyD
Sooooo... If you're the "King", then Fst is the "Q"?...
Old Apr 1, 2010 | 10:29 AM
avarvarigo's Avatar
avarvarigo
Hey guys. thanks for every additional update, i appreciate it. What i would like to ask at this point is, people are suggesting LED lights to bulbs, (brightness etc...), i am a bit leery due to reliability, polarity etc. Also availability of replacements. What do you think?
TV
Old Apr 1, 2010 | 12:39 PM
Dans01Durango
T, don't take this the wrong way. But I think AZ should have all you need to install the side flasher. I may look into that myself!
Old Apr 1, 2010 | 02:03 PM
avarvarigo's Avatar
avarvarigo
Sorry, AZ?
TV
