02 Durango Electrical Problem
Old Apr 21, 2010 | 10:06 AM
outspoken10's Avatar
outspoken10
Default 02 Durango Electrical Problem
Help! My 02 Durango currently has no headlights,interior lights, power door locks, wipers and my service 4wd light is on. I have checked the fuses and relays. Any ideas??????
Old Apr 21, 2010 | 02:04 PM
Dislander's Avatar
Dislander
ctm module failure. it plays into all of those systems. First check the fuses use a test light or meter not just a visual. then try disconecting the battery neg term & turn the ignition on while holding the brake pedal down for a good thirty seconds. turn the ignition back off & reconnect the battery.
That will reset the ecu clear all codes & from another posting here may kick the ctm back in.
But, check the fuses first.
Old Apr 21, 2010 | 03:26 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
Originally Posted by dislander
ctm module failure. It plays into all of those systems. First check the fuses use a test light or meter not just a visual. Then try disconecting the battery neg term & turn the ignition on while holding the brake pedal down for a good thirty seconds. Turn the ignition back off & reconnect the battery.
+100000000000
Old Apr 21, 2010 | 04:07 PM
hydrashocker's Avatar
hydrashocker
Ctm..
