camshaft position sensor
Old Apr 27, 2010 | 12:56 AM
mrwilliwizard's Avatar
mrwilliwizard
Default camshaft position sensor
where might this little guy be located on the 4.7l engine? thanks
Old Apr 27, 2010 | 09:33 PM
hydrashocker's Avatar
hydrashocker
The Camshaft Position Sensor (CMP) on the 4.7L
V–8 engine is bolted to the front/top of the right cylinder
head (Fig. 7).
(1) Clean out machined hole in cylinder head.
(2) Apply a small amount of engine oil to sensor
o-ring.
(3) Install sensor into cylinder head with a slight
rocking action. Do not twist sensor into position as
damage to o-ring may result.
CAUTION: Before tightening sensor mounting bolt,
be sure sensor is completely flush to cylinder head.
If sensor is not flush, damage to sensor mounting
tang may result.
(4) Install mounting bolt and tighten to 12 N·m
(106 in. lbs.) torque.
(5) Connect electrical connector to sensor.
(6) Lower vehicle.
Old Apr 28, 2010 | 08:04 AM
Dans01Durango's Avatar
Dans01Durango
Where's fig. 7?
Old Apr 28, 2010 | 10:03 PM
hydrashocker
