Step by Step Directions for Removing/Replacing CV Joints
Old May 10, 2010 | 04:48 PM
samsammy23's Avatar
samsammy23
Default Step by Step Directions for Removing/Replacing CV Joints
Does anyone have or know where I can get step by step directions for removing and replacing the CV joints/shafts on a 2001 Durango R/T?
Thanks in advance.
Old May 11, 2010 | 12:40 AM
hydrashocker's Avatar
hydrashocker
Brake the large wheel bearing nut/s loose BEFORE you jack up the truck and make sure you have a good sized cheater bar handy to do it.
You have to remove the wheel, brakes, hub (main and three bolts on back to knuckle), Also it you pull the tie rod end you can crank it over enough that you can pop out the CV from the knuckle without any more disassembling. When installing the new CV Halfshaft make sure they POP in to the axle housing.
Here is some info as well: https://dodgeforum.com/forum/1st-gen...sh-repair.html
