Auto tranny
Old May 11, 2010 | 10:24 PM
liblib54's Avatar
liblib54
Default Auto tranny
For a 2000 Durango with the 5.9L engine auto 4X4, is there a band that needs adjustment?. if, how do you know it needs adjustment. Thanks for the help.
Old May 11, 2010 | 11:09 PM
gr8scott72's Avatar
gr8scott72
Actually, two bands and they need regular adjustment.
Old May 12, 2010 | 09:19 AM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
you there are 2 of them, i believe you have to drop the pan so it is best done when you are changing the fluid and filter anyway, hydra or master tech will have the details for you
Old May 12, 2010 | 07:20 PM
hydrashocker's Avatar
hydrashocker
Here is the Front Transmission Band Adjustment, Rear Transmission Band Adjustment, and Gear Adjustment Procedure for the 2000 Durango 46RE Transmission:
You need an Inch lbs Torque wrench.
Old May 12, 2010 | 11:21 PM
liblib54's Avatar
liblib54
Great answers, but when will you know you need an adjustment?.
Old May 13, 2010 | 12:40 AM
IndyDurango's Avatar
IndyDurango
Every 24 months or 36k mile pan drop, filter swap and fluid change. That's when.
Do the diffs then too.
IndyD
Old Dec 2, 2010 | 03:43 PM
gzuz's Avatar
gzuz
sorry to revive this old post but for the front band when it says back the screw off 2-7/8 turns, does it actually means almost 3 turns?
Old Dec 2, 2010 | 08:26 PM
sparkmarv's Avatar
sparkmarv
Yes, mark the screw (before you touch it) and do 2 complete turns, then 7/8 of a turn so turn like 90% of the way, at most exact number would be 87.5%
Old Dec 3, 2010 | 09:20 PM
hydrashocker
No,
Mark the inside bolt and the Transmission in a straight line.
Then loosen the lock nut (#1). Then with an inch pound torque wrench, torque the inside bolt (#2) to 72 in. lbs. Then back off the SAME (#2) inside bolt 2 7/8 turns and tighten the outside lock nut (#1) while holding the inside from turning.
What you are trying to do here is wrap the band around the clutch tight (72 in. lbs) then back it off so the clutch can spin openly without the clutch being being held in place. The actual adjustment is the area between the clutch and the band (AKA.....2 7/8 turn off the set screw).
Old Dec 5, 2010 | 03:49 AM
gzuz's Avatar
gzuz
done... smooth manual shifts only.. when i set her on Drive, wont shift back to 2nd or 1st from 3rd... she goes into overdrive tho...
