Power windows and cd player
Old May 12, 2010 | 05:07 AM
Victim44's Avatar
Victim44
Default Power windows and cd player
I just bought a 2002 Durango and I have a few questions about it. First for some reason my power windows will only work with the driver controls. I have pushed the window lock button but that does not change anything. Second is most of the time my cd wont eject. It will come out about 1/8 of and inch and then sit there for about 5 seconds then get sucked back in. Any help would be greatly appreciated. Thank you
Old May 12, 2010 | 09:24 AM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
grab the cd when it is sticking out and see if it will come out the rest of the way, the eject mechanism could be getting weak
on the windows, the lock button could be stuck in the on position of you could have a loose connection in either the drivers door connector, OR in any of the other doors which could easily cause problems
Old May 12, 2010 | 07:29 PM
hydrashocker's Avatar
hydrashocker
Most likely a bad Master Door Switch.
