IAT sensor
I was doing the budget mod of relocating the IAT sensor to the intake tube. And when I pulled the sensor from the intake it was wet. I thought our intakes are dry. The fluid felt alittle greasy kind of smelled like oil. The odd thing is I only loose about 1/2 to 3/4 quart every 3k miles. Now I do have a mystery coolant leak along with an overheating issue. Is the wet sensor normal? Or do I have more issues?
the IAT shouldnt be getting wet period
if you have a 5.2 or 5.9l engine take off the air hat, and look down the throttle body with the butterfly open, if you see oil in there you have a bad plenum gasket, would also explain the amount oil you are using
The IAC is in the TB on that year and motor so there is absolutly NO way that a plenum leak could get to it. Most likey it's just very fine dust with a settling essence of settled fuel in distilled form.
Personally, I would leave it alone.
