Noise/Grinding while driving
Old May 22, 2010 | 04:53 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
glad you got it fixed
Old May 24, 2010 | 09:29 AM
Dans01Durango's Avatar
Dans01Durango
Happened to me once. Turning left would produce grinding noise. No noise turning right. So I replaced the RIGHT bearing assembly and noise was gone. For the record, when you turn, you put pressure on the OPPOSITE /outside corner of the vehicle. Which means the if you turn right, the left hub assembly is bad, if you turn left, the right hub assembly is bad.
Old Nov 23, 2014 | 03:24 PM
Djander's Avatar
Djander
Default 2000 dodge durango R/T 5.7
I just had the transmission rebuilt less then 7,000 miles on it all the sudden today i was slowing down to make a turn when i started hearing a grinding type of noise it is all wheel drive it sounds like could pissibley be comeing from the transfer case or rear end it doesnt do it till u hit about 35-40 and it starts it all at once any one have any suggestions
Old Nov 23, 2014 | 03:26 PM
Djander's Avatar
Djander
And it will kick in and out i can feel it in the stearing wheel sounds like two gears rubbing together
Old Nov 24, 2014 | 05:35 PM
asphaltwarrior1's Avatar
asphaltwarrior1
You dig up a 4 yr old thread about wheel bearings to post your problem that is clearly not a wheel bearing by your description? Would be better if you started your own thread . Might get more responses.
