Can I Remove the Bolt/Flange on the Back of the Front Diff?
Old May 21, 2010 | 08:47 PM
samsammy23's Avatar
samsammy23
Default Can I Remove the Bolt/Flange on the Back of the Front Diff?
I had some trouble getting the driveshaft out and wanted to know if I can take the flange off of the front diff. Will this mess anything up in the diff?
Thanks.
Old May 21, 2010 | 09:00 PM
hydrashocker's Avatar
hydrashocker
YES!!!!!!!
Don't touch the Pinion bolt int the center of the yoke on the front diff!
Whats the issue with removal of the U-joint?
Old May 21, 2010 | 09:47 PM
DanD1984's Avatar
DanD1984
How are you going to get the pinion nut off without taking the u-joint off??? That is impossible...
Old May 22, 2010 | 11:19 AM
samsammy23's Avatar
samsammy23
I could barely get it out because part of the exhaust and the flange off of the diff were in the way. It would be quite simple to reinstall if the flange was not in the way.
Old May 22, 2010 | 03:32 PM
hydrashocker
This is correct!
Anyway Sammy is talking about something completely different than what we are Dan. Pictures say a thousand words.
