99 durango cranks for awhile before it starts
Old May 25, 2010 | 01:31 AM
why did i buy a dodge?'s Avatar
Angry 99 durango cranks for awhile before it starts
I have a 99 durango that when i go to start it it takes roughly 10 seconds to start. The starter works instantly but truck doesnt fire til after the ten seconds or so. I can turn the truck off right after i get it started and it starts up right away. Someone please help me
Old May 25, 2010 | 07:27 AM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
do this next time you want to start the truck
turn the key to on and wait for it to prime (you SHOULD hear the pump running when you first put the key on, when it shuts off its done) probably about 10 seconds, then turn the key to start, if that works then the valve that is supposed to stop the fuel line from draining back into the tank is bad
Old May 25, 2010 | 12:42 PM
ive tried that before and that doesnt seem to really help it either.
Old May 25, 2010 | 03:36 PM
shrpshtr325
THE ULTI-MOD
how old is your battery? how does it crank, does it sound weak?
Old May 25, 2010 | 04:00 PM
rcijr's Avatar
rcijr
shrpshtr325 - I need to turn my key to the on position a time or two before it will start. What is that valve called? Is it located in the engine compartment?
I was/am worried that this is a fuel pump problem, but would be much happier if it was a valve that is easily replaced.
I bought a '99 Durango with the 5.2 for my first Dodge.
Old May 25, 2010 | 04:04 PM
the battery is good and it cranks fast right away
Old May 25, 2010 | 06:42 PM
hydrashocker's Avatar
hydrashocker
He is referring to the anti-siphon valve that is part of the fuel regulator at the top of the fuel pump. The filter, pump, regulator, anti-siphon valve, and level float is one big unit in the tank. Yes you have to drop the tank to get to it and plan on forking out like $200 bucks.
Now back on topic, if after you turn the key in the on position for 10 seconds and it is still taking a while to fire then replace your spark plugs!
Go here and look up Tune Up: https://dodgeforum.com/forum/1st-gen...wers-faqs.html
