Radio off a 05 to an 02
Old Jun 30, 2010 | 07:09 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
ok well, that IS what the radio would look like out of the dash (for the most part) so it SHOULD fit just fine, you can buy adapters to go btwn the two different plug interfaces at walmart (i did it at one point, what it did was to plug an aftermarket unit into any chrysler stock plugs, but im sure it can be made to work like you want) (if not just go to a junkyard and cut the right harness out of a wreck)
btw, the 02 truck used the newer interface (at least mine does) so the new h/u was probably out of an older truck
Old Jun 30, 2010 | 07:11 PM
Fox Fader's Avatar
Fox Fader
You need to get a wiring harness for the truck, and a REVERSE harness for the radio. You can get these from scosche.com
With a pinout for each, you will be golden.
Old Jul 1, 2010 | 09:02 AM
Dans01Durango's Avatar
Dans01Durango
shrps, we have the same radio/climate control setup. But I'm probably stating the obvious here. So, what's a SOOL?
Old Jul 1, 2010 | 09:54 AM
shrpshtr325
THE ULTI-MOD
http://www.urbandictionary.com/define.php?term=sool
learn it, live it, dont make a fool of yourself anymore
Old Jul 1, 2010 | 10:22 AM
dsolis's Avatar
dsolis
Haha ^^^ thank you gentlemen.... I am a mission now....or i might just go aftermarket...we'll see...
Old Jul 1, 2010 | 10:38 AM
shrpshtr325
THE ULTI-MOD
i think the oem looks better than an aftermarket with an adapter plate jmho
Old Jul 1, 2010 | 10:45 AM
dsolis's Avatar
dsolis
I agree, thats why i went out to get the OEM cd player, but it backfired... Why couldn't Chrysler just make a double din....jeez...
Old Jul 1, 2010 | 02:57 PM
Fox Fader's Avatar
Fox Fader
It may look better to some but my Kenwood looks AND sounds way better.
Old Jul 1, 2010 | 04:24 PM
Overcast72's Avatar
Overcast72
I like my Clarion too Plus it plays MP3's right from a flash drive. I still have the 2003 Stock CD player - problem was the rails on the inside that the laser moves on, seemed to be 'sticking' I guess - the CD would skip even if the truck was sitting still.
But the 2003 Radio is identical to that 2002.
Old Jul 1, 2010 | 05:14 PM
shrpshtr325
THE ULTI-MOD
yup 01-03 (i think 04 even in the dakotas) used the same radio
