Nuetral saftey switch
Old May 2, 2009 | 09:53 PM
cyborg67's Avatar
cyborg67
Exclamation Nuetral saftey switch
hello everyone i am needing some help on where the nutral safety switch is located at on 98 durango 4x4 5.9
Old May 3, 2009 | 01:12 AM
IndyDurango's Avatar
IndyDurango
I don't think we are supposed to post in this thread. Nevertheless, the neutral safety switch is located on the transmission. Takes about 15 minutes to swap out. You will loose some fluid. It is right above the front drive shaft and below the shift linkage. Pop off the electrical bail on the top of the sensor and use a 1" deep well socket to remove.
HTH,
IndyDurango
