More smoke
Old 10-11-2012, 02:21 PM
jmess's Avatar
jmess
jmess is offline
Default More smoke
So a few months ago my truck started smoking pretty bad. I already needed to replace my plenum gasket so I did. Now today it started smoking again. It doesn't do it when I drive. Only when I'm stopped for a minute and then hit the gas and then it eventually goes away till I stop again. I'm stumped at this point. I'm throwing no codes either. I have noticed a build up of oil on each end of the breather that goes from the driver side valve cover to to air hat. And when I pull the hose off the air hat there's oil in it. Coul this be the issue and how do I fix it
Old 10-11-2012, 04:38 PM
Sooper's Avatar
Sooper
Sooper is offline
Maybe your valve seals are probably shot. Oil is leaching it's way around the valve stems and entering the combustion chambers. You can do a compression test and a leak down test. If you have good compression but it leaks down fast the seals might be bad. If the compression sucks, the rings might be toast and oil is making it up past the rings and entering the chamber that way.
Old 10-11-2012, 05:28 PM
jmess's Avatar
jmess
jmess is offline
I went to go to the store and my engine light came on. Misfire on cylinder 4. It makes since because the smoke didn't smell like oil. I'm thinking it was from gas pooling when I was stopped. Installing new plugs now and we'll see if anything changes.
Old 10-12-2012, 12:03 AM
jmess's Avatar
jmess
jmess is offline
So even after the plugs it's still smokes.
Old 10-12-2012, 01:10 AM
cummingetit's Avatar
cummingetit
cummingetit is offline
Bad pcv valve sucking oil through the hose?
Posted from Dodgeforum.com App for Android
Old 10-12-2012, 01:33 PM
jmess's Avatar
jmess
jmess is offline
Possibly. I didn't even think of that. Ill try it. Cheap fix
Quick Reply: More smoke
