Spindle nut can be re-use?
Old Jul 17, 2010 | 04:03 PM
01DurangoFl's Avatar
01DurangoFl
Default Spindle nut can be re-use?
I'm going to replace my front wheel hub and the parts dep at the dealer is closed, can I re use the same spindle nut? its got in writing not to re use
Old Jul 17, 2010 | 08:01 PM
Fox Fader's Avatar
Fox Fader
You can reuse them. I have in many, many applications with no problems.
Old Jul 17, 2010 | 10:20 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
i dont see why you cant reuse them either, unless you damaged them, or they have something on there that would bend into place as they tightened to stop them from backing out (that would have to be broken off to get the nut off)
Old Jul 17, 2010 | 11:57 PM
hydrashocker's Avatar
hydrashocker
Yes, but it needs to be torqued to 180 ft/lbs torque however sense it has been torqued before I would torque it to 182 just to be safe.
Old Jul 18, 2010 | 12:34 AM
Fox Fader's Avatar
Fox Fader
2 ft/lbs won't make much of a difference when you get that high. Even a good TW can't tell the difference.
Here is a good vid, love the voice over. haha
http://www.youtube.com/watch?v=Tq4wr7gcwnE
Old Jul 18, 2010 | 01:38 AM
hydrashocker
Boy here we go again huh?
After you torque a bolt the "torque a bolt or nut" means "stretching a bolt or nut" the bolt stretches. You can only stretch a bolt one time and that is it! However you can strech a bolt or nut "further" causing a true torqued bolt/nut. If you go the same or under then you do NOT stretch a bolt correctly hints the reason you have replace head bolts and like wise. You can always over stretch "torque" the bolts with caution but you cannot under torque or same torque the bolt or nut that has already been torqued.
New head bolts are used because you cannot safely over torque "stretch" the bolts correctly. However you should never re-torque bolts that have already been torqued because the OEM torque is set for a reason.
Yes I said 2 f'lbs but that's better than nothing for over torque. Can a good torque wrench tell the difference, no, however just to be safe.
But hey what do I know!
