Changing Speed Sensor
Old May 20, 2005 | 09:18 PM
ezwider808's Avatar
ezwider808
Default Changing Speed Sensor
Just wondering if anyone can tell me how much fluid i should have to replace in the transfer case once i pull the old sensor out.
Old Jun 5, 2005 | 03:05 AM
blackdodge's Avatar
blackdodge
Default RE: Changing Speed Sensor
none. The sensor is on top off the diff case. Since your under there you might change the gear oil. 3.2 quarts i think with the trac-lock additive also.
Old Jun 13, 2005 | 02:13 AM
rockadaous's Avatar
rockadaous
he's talking about the speed sensor on the tranny. not the rear wheel speed sensor. The answer is still none though
Old Jun 16, 2005 | 05:11 PM
317Ryder's Avatar
317Ryder
Hi I have a 1999 dodge durango and I noticed when I am pulling off that my speedometer doesn't pick up until I hit around 30 MPH. What causes this and how do you suggest it can be repaired....as sensor?
