Bouncing idle
Old Aug 5, 2010 | 04:01 PM
DGauss's Avatar
DGauss
Default Bouncing idle
2002 durango with 4.7L
The idle bounces between 750 & 1200. If I clean the throttle body it stops for about a week. I took the K&N air filter out and replaced it with a paper filter, cleaned the throttle body, all was good for about one week again.
Any ideas would be appreciated!!
Dave
Old Aug 5, 2010 | 05:31 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
check the IAC valve and the TPS (does it do this at cruising speed to any extent, might be less noticeable when driving)
Old Aug 5, 2010 | 06:12 PM
hydrashocker's Avatar
hydrashocker
If it surges with the cruise control on more than idle then replace the TPS. If it's just on idle replace the IAC.
Old Aug 5, 2010 | 08:42 PM
Mcstealth's Avatar
Mcstealth
Default Read this thread!!!!
https://dodgeforum.com/forum/1st-gen...ions-help.html
David
Old Aug 6, 2010 | 08:14 AM
DGauss's Avatar
DGauss
The engine is steady all except when sitting at idle. No codes thrown. I can read the live data stream for the TPS, should it move at all ?? The idle air , how can it be checked ??
Old Aug 6, 2010 | 05:25 PM
shrpshtr325
THE ULTI-MOD
the tps should change as you press the gas pedal, but be pretty steady at idle, the iac, i have never heard of a test for it unfortunately
