Rim Size Question...
Hey,
I have a 2002 dodge durango with 2 sets of 16" factory rims. I was thinking of trading one set for a 15" factory rim. My question is will the factory 15" rim have any fitment issues as far as clearance since the durango came with the 16" or will I be able to do this with no problems?
it depends on which size brakes you have i THINK the bigger front brakes were only on the 03 trucks, but make sure, if you have two piston calipers on the front brakes the 15 inch rims will NOT fit, however, if you have single piston calipers up front, they most likely will (as hydra said)
