Cooling Issue
Old Aug 24, 2010 | 03:09 PM
hydrashocker's Avatar
hydrashocker
Fans have CFM's all over the place! You should use the right one for the job and ensure you have no issue.
If the A/C is shutting down and you are at about 210 then the PCM is doing it's job in shutting down the A/C to keep it from overheating. It is ment to do this! ALso you might have a T-stat going out so replace.
Take her truck to the car wash, open the hood, and spray out the condenser to ensure you have good flow into the radiator.
Old Aug 24, 2010 | 05:36 PM
dodgehoodup's Avatar
dodgehoodup
Everything is good except the after market fan which isn't up to par.
