Another A/C Question (2000 Durango, 4.7L, Rear Air)
Old Sep 8, 2010 | 09:44 PM
elittleton73's Avatar
elittleton73
Here's an update. After evacuating the system and recharging I've still got problems. I think I've got a blockage because after going from idle to around 1000 to 1500 rpm's, the low side drops from about 33 psi to around 25 psi and the high side goes from around 250 psi to above 350 psi. I'm going to replace the two expansion valves like suggested and replace the drier. I also would like to flush the condenser. What is the best way to flush. Does it need to be completely removed and what is the preferred flushing solvent/liquid? And I probably should flush the evaporator?
I haven't done this before so this is new, but after reading the manual I downloaded from this sight I have a question. Am I required to have the proper A/C line disconnect tool for removing the refrigerant line coupler? It says it is Special Tool Kit 7193. Or can I use something else like pliers and a screw driver? I don't want to damage anything so I thought I would ask.
Old Sep 8, 2010 | 10:55 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
the A/C system is something i wouldnt mess with myself, only bc whenever you open the system you release toxic chemicals into the environment,(the epa doesnt like this and hands out hefty fines to those caught doing it) and the equipment to work on these systems is soooooo expensive that its not worth the investment for a shade tree mechanic to do own.
and im NOT sharing my scotch, . . . (or the cigar )
Old Sep 8, 2010 | 11:41 PM
Dans01Durango's Avatar
Dans01Durango
+1 on taking the D into the shop for repairs concerning a/c systems.
Pssst... The scotch is for shrps to get drunk and the cigar is for him to pass out so we can take HIS D for a joy ride!
Old Sep 9, 2010 | 06:48 AM
neogeo's Avatar
neogeo
the quick disconnect tools are similar to the ones used to change the fuel filter on a ford.. they are lil plastic rings that slide over the line and pushed in to the release the spring loaded coupler. you can get them at any parts place and they arent expensive but can be a major pain cause of being hard to get to . but if you have never done it before and dont have a recovery machine to contain the freon i would take it to a shop and have it done they can also flush the condensor and evap core.
Old Sep 9, 2010 | 09:39 AM
shrpshtr325
THE ULTI-MOD
your gonna have to pry the keys out of my cold dead hands
Old Sep 9, 2010 | 04:31 PM
hydrashocker's Avatar
hydrashocker
That's ok,
Well just throw your passed out *** in the passenger side with your hand still attached to the keys and take it for a good muddin & bury it! Then well vacate, when you awake you'll think you did it!.......
Old Sep 9, 2010 | 05:29 PM
shrpshtr325
THE ULTI-MOD
good lucky trying to move my fat *** around if im passed out, however ifyou bring your truck over we can take that off-road, maybe show my dumbass neighbor how off-roading is REALLY done (hes an idiot that drives a stock wrangler and thinks he can off-road, but he spends more time hooked up to a tow rope than the does under his own power)
Old Sep 10, 2010 | 02:21 AM
fpsweet's Avatar
fpsweet
if you do it your self carquest sell a flush you blow through the lines after they have been disconnected from your compressor, but it sounds like to me to much oil is in the system or you expansion valve craped out the front one is near the fire wall and the rear is under the trim in the rear on the passagerside make sure you use metric and the correct torx head and impact swivel to remove the rear seat and belts,swivels for the rear seat.
a/c is easy. really not much to remember, just keep it clean
Old Sep 10, 2010 | 09:30 AM
neogeo's Avatar
neogeo
its easy for people that have done it before and know what they are doing.just like rebuilding an automatic transmission.. its easy not much to it. IF you know what you are doing .
Old Sep 10, 2010 | 12:34 PM
Dans01Durango
Exactly, neogeo! It's easy IF you did it before. To the OP, take it to a trusted a/c shop and see if you can hang around when they do the repair/install. Take mental notes and next time it'll be easier on your wallet.
