does T/S lift reduce travel?
Old Sep 10, 2010 | 12:28 AM
Magoo's Avatar
Magoo
Default does T/S lift reduce travel?
thought I read somewhere that the travel on the '02 was 8". Planning on doing the T/S lift, so I'm wondering if this "cycling" of the suspension to get the lift is reducing the travel.
Old Sep 10, 2010 | 12:40 PM
Dans01Durango's Avatar
Dans01Durango
To my way of thinking, if you increase the ride height, don't you also increase the suspension travel due to the added height?
Old Sep 10, 2010 | 01:46 PM
hydrashocker's Avatar
hydrashocker
You should get MORE height because on compression at OEM you are only a short distance, however if you lenthen the bump stops from the control arm you will get more. On the down side, you can only go as far as your shocks, brake lines, and metal will allow and that distance should be the same regardless as far as inchs.
With that said, regardless you will have more with a T/S lift over OEM height.
