02 Durango SXT brake problems
Old Sep 27, 2010 | 05:57 PM
JDre's Avatar
JDre
Default 02 Durango SXT brake problems
Have brake issues, severely grabbing and jerks upon stopping, had front/rear pads and shoes replaced, front/rear rotors and drums replaced, brake fluid drained, flushed, and replaced, and front calipers rebuilt. ABS on rears only. Problem is still there and continues to get worse. Took to several shops including Dodge and all say they can't find a problem. Any other suggestions? I'm on my last nerve with this issue. Consider this a safety concern.. Thanks
Old Sep 28, 2010 | 03:50 PM
hydrashocker's Avatar
hydrashocker
Rust can cause this to happen but usually it alleviates after the first couple of stops. Get going down the road and place your foot lightly on the brake and slowly push harder as you start to loose speed gear down and open up the throttle while holding down the brake. Do this for about 1/4 to 1/2 mile. Now this is going to heat up the brakes so be careful. Now see if they are still grabby.
If they are still grabby, try like you're coming to a very hard stop from a large speed (like 80mph) onto an off ramp or similar and you forgot the stop sign was right there. I mean a very hard stop but WITHOUT locking the brakes up. Do this on cold brakes only!
What I am getting at here is if you have pitting in the rotors from rust it acts like sand paper and makes stopping like a grabby jerk. If you can get this to ware off you'll be in good shape. Also watch where you park as the sprinkling system can get water on your rotors continuing the rust and your back to square one again each day.
Old Sep 29, 2010 | 12:13 AM
IndyDurango's Avatar
IndyDurango
90% chance that the rear shoes need adjusted (again.) Believe it or not.
I suggest bleeding the system correctly at all five spots and have the rears adjusted again. Have it done at a busy and active brake shop because they will have the most experience and familiarity without costing you a dealer-ton-o-cash or have to deal with a jack-of-all-trades grease shop.
IndyDurango
Old Sep 29, 2010 | 04:09 AM
JDre's Avatar
JDre
Thanks guys for the tips, I'll try both and see where it gets me. I was hoping that after all the parts, labor, and money put into them they would be fixed. I'll keep you posted.
