P1762
Old Oct 31, 2010 | 09:24 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
glad you got it fixed man, and thanks for posting up and letting us know
Old Nov 17, 2010 | 04:58 PM
gzuz's Avatar
gzuz
nice post! thx for the info!
ive been having troubles with my 46re tranny... erratic shifting... but it gives me no codes.. any ideas on what it could be?
the T.V. cable is properly adjusted my next guess is bands adjustment and in the worst case... hydaulics falure...
T.T
S!
Old Nov 17, 2010 | 09:24 PM
shrpshtr325
THE ULTI-MOD
sounds like you need to have the bands adjusted and the filters changed while you have it opened up
Old Nov 18, 2010 | 03:24 PM
Dman98's Avatar
Dman98
I had the same symptoms before I got the code.
Old Dec 2, 2010 | 07:06 PM
Dman98's Avatar
Dman98
Hopefully the last update. The code came back, I dropped the pan and found silver metal in it. It wasn't much, but I figured it was time to take in to have the tranny checked. I was told the cooler in the radiator was bad and had aluminum circulating in the trans fluid. I also had a bad torque converter. The trans was rebuilt, the converter was replaced as well as the sensors. They bypassed the cooler in the radiator and install a external tranny cooler. I just got her back, they had her for two days. I post how this are going, she feels like a new beast. Btw, I still have the BW solenoid I swapped it before I took her in for repairs. I'll replace the radiator in the summer with a 3 core if one will fit.
Old Dec 3, 2010 | 08:45 PM
hydrashocker's Avatar
hydrashocker
I don't know of a 3 core, never found one?
All I ever found is a 2 core (or row) aluminum with plastic caps (AKA....Original).
Old Dec 4, 2010 | 05:56 AM
Dman98's Avatar
Dman98
I've only been able to find 2 row, so that's what I'll be getting. I'll be keeping an eye on the connections for leaks, since they used regular clamps to attach the pressure hose to the cooler. I won't be making any changes until the warranty expires in 1yr, I don't want them to blame it on my changes if somethings goes wrong with the tranny.
Old Dec 5, 2010 | 09:36 PM
hydrashocker
+1 Dman
