window issues
Old Oct 17, 2010 | 11:04 PM
jl10w3s's Avatar
jl10w3s
Default window issues
so im having some random window issues and just wanted to know if anyone else is experiencing the same problem. If so, how did you fix the problem. Every now and then the three passenger doors have no up/down window function and can only be controlled from the main drivers control. i ve checked the window lock and tried it after locking and unlocking them several times and they suddenly work again. i think that my window lock switch and/or relay is getting stuck in the engaged function but wanted to see what others have to say. all help is greatly appreciated. thanks
Old Oct 17, 2010 | 11:36 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
check/reseat the plug into the driver door window control switch, the other option is to replace that master switch as it sounds like it is malfunctioning, could be that you got water in it.
Old Oct 18, 2010 | 09:20 AM
Dans01Durango's Avatar
Dans01Durango
+1 on the master control switch. Use a flathead and gently pry it off the armrest. No screws, test for continuity and clean off contacts. Put some bulb grease on contacts and try operating the windows and locks. If still not working, time to see the junk man.
Old Oct 18, 2010 | 01:31 PM
BikeBuilders's Avatar
BikeBuilders
Mine rear windows sometimes work, sometimes don't... No matter what switch you use.
Old Oct 18, 2010 | 04:44 PM
shrpshtr325
THE ULTI-MOD
bikebuilders, that sounds to me like there is a bad connection going to the rear motors, but please start a new thread for your issues
Old Oct 19, 2010 | 11:32 AM
hydrashocker's Avatar
hydrashocker
Also could still be the drivers master door switch as the diodes could be bad in it.
