regearing!
What I offer is from what I have read on here AND what I have experienced first hand in my own truck.
Cheers!
True, but you did say that 4.56s would have no top end and get horrible mpg. Neither of those is correct.
And that's why I'm going to 4.10's with a 33" tire. This should make around a 3.78 ratio or so, and with that I should get the best ratio with low end and high end fuel mileage. But then again I am talking about 2 different vehicles.
Wizard:
Having AWD does not affect the performance of your D as negatively as you think.
This is because all of its 4800 pounds and extra 4x4 hardware are there whether or not it is part time or full time 4x4.
The 4.7 engine is a great motor. My previous 01 D had one, and it was trouble free. Now that I have an 04 Hemi, I can see that the 230hp in my 01 was not the powerhouse that the 330 hp Hemi is.
If you do regear, I would recommend going with the 4.10 gears. Going from 3.55 to 4.10 is quite a change. Going all the way to 4.56 will help around town since you will only have to breath on the gas pedal to get moving. Your loss will be on the hwy where the higher rpms will eat the gas like no other.
If you can do it yourself (most folks don't have the know how or tools), you can probably do it for about $1k. Double that if you pay to have it done. In any case, you will want it done right and right the first time.
Don
Don
4.56 gears will not eat the gas like you think it will.
Don't fear the gear.
You might be able to get the ring gear and pinion for $400 but you forget about the "Other" parts when you get into the differentials. First you NEVER just replace the ring and pinion by it's self, you ALWAYS do a full rebuild!
Ring and pinion
Master bearing kit including shims
LS (if installed) clutch packs
Axle seals and Bearings
Yoke
Trust Washers for spiders
Spiders if needed
Hypoid lubrication, Friction Modifier (if LS), Grease (for seals)
Shop Supplies
Then you need the special tools!
