stalling auto???
Old Oct 31, 2010 | 01:46 AM
TCMaster's Avatar
TCMaster
Unhappy stalling auto???
This has been a nonissue for me, but very occasionally (by which I mean it has only happened twice), my Durango has stalled. Both times I was reversing slowly, and it just pooped out on me. Started up fine and drove off right after. If it stays like this it won't bother me, but I know automatics are not supposed to stall, and I am curious as to what it might be.
Old Oct 31, 2010 | 02:22 AM
Sixtysixdeuce's Avatar
Sixtysixdeuce
Doubt it has a thing to do with the transmission. Are there any DTC's in memory?
Old Oct 31, 2010 | 02:55 AM
TCMaster's Avatar
TCMaster
no idea... i'll get back to you on that.
Old Oct 31, 2010 | 02:57 AM
TCMaster's Avatar
TCMaster
P0037... what does that mean?
Old Oct 31, 2010 | 10:02 AM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
was the steering wheel turned all the way to either side when it happened???
P0037 HO2S Heater Ctrl Circ Low Bank1 Sens2
sounds like your heated o2 sensor needs to be replaced (might be a loose connection somewhere in the circuit too)
Old Oct 31, 2010 | 03:35 PM
TCMaster's Avatar
TCMaster
Come to think of it, it was, because I was backing up in my driveway, which has a very sharp corner.
Old Oct 31, 2010 | 09:27 PM
shrpshtr325
THE ULTI-MOD
there it is, i have seen quite a few cars do this if you have no gas pedal into it and the wheel turned to full lock and you keep pushing it that way will cause this. mine has done it once. if it becomes a regular occurrence to the point it gets annoying i would look into it, otherwise i wouldnt worry about it
Old Oct 31, 2010 | 10:20 PM
TCMaster's Avatar
TCMaster
ok, well I will leave it alone, and hope it doesn't bother me.
