Brake Prob. 1999
Hi i Have a 1999 durango and I am having big problems with the brakes.. Firstly the front calipers and disc and drums, and brake lines have been replaced just about 5 months ago.. Now the breaks are leaking fluid somewhere, because at some point the pedal goes practically to the floor and is hard to brake. We bled the lines and refilled the brake fluid but the problem still exist. Yesterday after I ran to town it had only a little bit and within about an hour that little bit was drained its leaking somewhere from around the engine bu i don't know where to check... Help please! Thanks
If you think that it is coming from some where around the engine try checking the master cylinder where it connects to the brake booster or any of the brake lines that come off of the master cylinder itself.
