my ABS and brake light fix
Old Nov 8, 2010 | 06:21 PM
spectre184's Avatar
spectre184
Default my ABS and brake light fix
Hi all,
Wanted to let you all know how I fixed the ABS and BRAKE cluster light. Plus speedometer didnt work until 60mph.
I have put in new rear speed sensor couple times and still had problem. I went to junk yard and got another ABS control module and still had ABS and BRAKE cluster light and check engine. I have access to scanner and it said speed sensor but I got it confused with tranny sensor so I didnt realize they meant sensore on rear differential. I then found this website: http://www.ricksfreeautorepairadvice...er-doesnt-work and followed instrustions. I had bad wires. I ohmed from module to back and it was open. Since I replaced speed sensor before I had pigtail harness. I ohmed that thru sensor and it was good. I went back to ABS module and uncovred wires back and stripped littel bit of insulation off where I was gonna splice and ohmed checked from wire to plug that goes into ABS modle. It was ok so I didnt have to take plug apart like link said too. So I took that pigtail harness off and cut wires in half. Got some 18 gauge speaker wire and spliced into pigtail and ran undernearth following wireloom to engine compartmant. I didnt put wire into wireloom but if you wanted to take time you could. I just zip tied everything out of way. I spliced into plug into engine module and now everything works! No ABS, BRAKE or check engine (due to speed sensor not reading).
Old Nov 8, 2010 | 06:37 PM
spectre184's Avatar
spectre184
Also.... My abs control module was bad after all. I put orignaol in and my lights came back on.
