Will turn off when i take foot off gas
the other day i started my dodge durango 2003 slt 2 wheel drive. Drove to gas station and filled up. Wh en i turned my truck one it died right away like the battery was dead. Tried a second time and it started, put into drive steped on gas and i moved when i took my foot off the gas and put onto brake it just died. I got it back to my house by keping my foot on gas even when stoped. What could be wrong it will turn over and start but once you give it gas then stop it turns off. Thank you for any info.
I live in FL. When i took the cover off the throttle body i saw that my vacuum hose was cracked at top and bottom just to see i taped it up and the problem went away to a degree i could step on gas take foot of and it would stay on, I'm going out in the morning to get a new hose and pcv also a battery because it is time. If that dose not fix it then i will replace the IAC thank you for your thoughts.
i had a 91 mitsubishi elclipse gsx all wheel drive turbo, and it did that same thing. but much more of a pain in the *** to keep it running as it was a standard tranny. it will start and as soon as you let your foot off the gas it dies. i spent like $1000 bucks trying to fix it, replaced the catalytic converter, the throttle position sensor and other random stuff that i thought might be causing it. then just for the hell of it, i started checking all my fuses in the vehicle and it ended up being a damn .05 cent fuse. start with the stupid stuff first!!
