180 deg. stat or OEM?
Old Nov 14, 2010 | 01:22 AM
DurangoOwner's Avatar
DurangoOwner
Default 180 deg. stat or OEM?
Hello, first post. I own a 98 durango with the 5.2. I am at 120K and I am about to flush the cooling system and replace the thermostat. Would you guys advise installing a Jet 180 deg thermostat (part no. 10170) or stick with the OEM 195 deg stat? Would I get more or less MPG with the 180? My engine is stock. Thanks for your help.
Old Nov 14, 2010 | 10:13 AM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
the 180 stat is a good idea int he 5.x series engines, you most likely wont see a difference in mpgs, however it is the temperature that the block was designed to run at and will help with the longevity of the engine
Old Nov 14, 2010 | 12:22 PM
DurangoOwner
Thanks for the reply! Will I still get enough heat this winter? Also, is this the only gasket I will need to replace?
http://www.amazon.com/Stant-25138-Th.../dp/B000C847OU
Old Nov 14, 2010 | 01:19 PM
shrpshtr325
THE ULTI-MOD
yes you should still get enough heat in the winter, just might take a couple extra minutes to get it. afaik thtas the only gasket
Old Nov 15, 2010 | 12:29 AM
hydrashocker's Avatar
hydrashocker
You should get enough heat, but think of the heads you will be saving from the heat of the 195 OEM......It's a good call with the 180.
Old Nov 15, 2010 | 11:40 PM
DurangoOwner
Thanks! I went with the Jet. I will be installing it later this week.
